CGNS - convert BC from node to face
Old   October 26, 2008, 11:42
Default CGNS - convert BC from node to face
Charles
IcemCFD gives one the option of exporting a cgns mesh with the BC applied at either node or face. However, Gridgen only seems to know about applying the BC to nodes. The solver's pre-processor wants face-based BC's. Is there an easy way of doing the conversion? A quick glance at the cgns documentation and tools did not produce an easy solution.
Old   November 1, 2008, 09:50
Default Re: CGNS - convert BC from node to face
John Chawner
Hi Charles,
The CGNS export in Gridgen was changed in July to be face-based. Pointwise's CGNS export is also face-based.
If you update your installation to Gridgen Version 15.12, you should be OK.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
