#21 |
Rep Power: 11 ![]() |
So i've implemented residuals (rms residuals) and also convergence between two iterations (rms convergence). I get oscillating residuals but all below 1e-5 whereas my convergence is monotonically decreasing. The velocity profiles predicted look okay. So which should i use as my stopping criteria, the residuals or the convergence?
#22 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
#23 |
#24 |
incompressible flow, parallel plates, simple |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
radiation b/w parallel plates | str6073 | FLUENT | 0 | November 18, 2013 07:42 |
Injection between parallel plates, homogenous mode | Terje | CFX | 7 | September 7, 2008 19:51 |
Flow between 2 parallel flat plates | pelli | FLUENT | 2 | July 14, 2007 09:59 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
