MCM modelling and thermal simulation
Old   September 9, 2015, 12:29
Default MCM modelling and thermal simulation
Samsam42
phurba is on a distinguished road
I am working on the project and I have to model a multi chip module and perform thermal simulation on the resistor mounted on the top.
basically, the multi chip module is made up of 96% alumina and 30% tungsten which is about 2mm thick. on it there are two metal oxide semi conductor mounted. the problem is steady state and I need to find the junction temperature between the substrate and the resistor.
how do I get started with this project? which software should I use? can I do it in workbench using steady state thermal analysis?
thanks for your help.
phurba
phurba is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Query regarding Modelling Thermal mass decomposition in star CCm+ himanshu28 STAR-CCM+ 0 April 30, 2013 03:43
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
