How to define fluxes for two dimensional convection-diffusion equation? |
September 9, 2015, 12:40 |
#21 |
Yes. U and V equals one. I just want to check my local mesh refinement algorithm and want to make sure that it is giving better result than when there is no refinement. Then later on, I would change it to be a dynamic mesh once the procedure turns out to be right.
September 9, 2015, 12:49 |
#22 | |
Filippo Maria Denaro
Rep Power: 73 |
local steady refinement can not help improving this kind of solution |
September 9, 2015, 12:55 |
#23 |
Why is that so professor? Say, I am validating my results along the centerline where there is a sudden jump of solution from 0 to 1. With local mesh refinement here along the center, should not I be able to manage to get a better solution?
September 9, 2015, 12:58 |
#24 | |
Rep Power: 73 |
this jump will rapidly move far from the refined region |
September 9, 2015, 13:01 |
#25 |
In my particular case with the boundary conditions that I am using, this jump remains in steady state. You can imagine a square with top and left sides on 1 and right and bottom sides on 0 initial value. At steady state, the center point of square is where the jump happens. You are right that in transient case, this will keep moving like a wave.
September 9, 2015, 13:08 |
#26 |
Rep Power: 73 |
your BC.s cannot be prescribed on all the edges of the box but only at left and bottom .....
September 9, 2015, 13:11 |
#27 |
Why is that so professor? I remember I have earlier solved 1D inviscid Burgers equation in which I had BC on both of the ends of domain. And how would I deal with the top and right two boundaries if this is the case? Periodic BC?
September 9, 2015, 13:18 |
#28 |
Rep Power: 73 |
that's wrong, the 1D Burgers equation requires only one BC. to be well posed.
September 9, 2015, 13:21 |
#29 |
For that case actually, I had used the initial condition and boundary conditions from the PhD thesis of Marsha Berger(who proposed adaptive mesh refinement for hyperbolic PDE that I want to use). But even with 2 BC, it got solved well.
September 9, 2015, 13:31 |
#30 | |
Rep Power: 73 |
I strongly suggest to better study the character of the equations and the required boundary conditions |
September 9, 2015, 22:19 |
#31 |
Thanks professor! So in my two dimensional case, what kind of BC will I need on the other two edges?
September 10, 2015, 04:41 |
#32 |
Rep Power: 73 |
finite difference, finite volume, math, mesh, pde |
Model crashes while solving advection diffusion equation | cooljd | Main CFD Forum | 3 | August 23, 2012 11:40 |
Spectral Element DG and the Convection Diffusion Equation | sspatelccny | Main CFD Forum | 0 | June 30, 2012 18:35 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Define an equation for the inlet velocity profile | Alshroof | CFX | 3 | January 9, 2007 20:34 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
