October 20, 2008, 11:19 |
Flat Plate Drag & Lift
At very high angles of attack, airfoils are supposed to behave like flat plates. I suppose that the formulas for the lift and drag on a flat plate are fairly well to be approximated analytically, aren't they? Does anyone know where I can find relations for drag and lift on a flat plate as a function of: - angle of attack - aspect ratio - Reynolds & Mach number ??? Thanks, Joe |
October 20, 2008, 15:34 |
Re: Flat Plate Drag & Lift
It's not quite that simple.
As far as I know, there is only one "exact" solution, and that is for potential flow. For a flat circular disk, the lift slope coefficient is C_L/AoA = 1.79002303 with a possible error in the last digit. |
October 24, 2008, 10:50 |
Thanks
October 24, 2008, 15:17 |
check "Fundamentals of Aerodynamics" by John D Anderson for some formulas for the flat plate. You can also check the NACA report server for additional informations about the flat plate experiments and theory. BTW the theory for flat plate works for potential flows (inviscid and irotational flows) and also for laminar flows (search for Blasius solution for the flat plate). The flat plate in turbulent flow is not covered very well by the theory but I'm sure you can find a lot of empirical formulas. Paul |
Drag on a flat plate | ac_ankit | Main CFD Forum | 0 | October 15, 2011 07:41 |
Calculate Drag force for flat plate | vsun | FLUENT | 0 | October 3, 2010 08:56 |
cavity in flat plate and drag prediction | Far | FLUENT | 0 | May 19, 2010 15:47 |
drag of flat plate with cavity | Far | FLUENT | 0 | May 18, 2010 05:57 |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 28, 2007 00:38 |
