error while execute on demand
Old   October 15, 2008, 07:59
Default error while execute on demand
Anderson
hi,i'm actually try to execute my udf file through execute on demand while the following errors occured:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Before that, the compilation goes well without any errors until reach execute on demand where it yield the above errors. i've try interpret as well but still the same errors come out. Can anyone give me some suggestions?
Old   October 16, 2008, 00:38
Default Re: error while execute on demand
Anderson
I try defined for the user defined memory before execute on demand but the same errors occurred again. Before that, the solution also has been initialized and iterate as well. The following is my source code. Can anyone tells me what is the causes of the errors?
#include "udf.h"
DEFINE_ON_DEMAND(calc_eq)
Domain *d;
real tavg = 0.;
real tmax = 0.;
real tmin = 0.;
real temp,volume,vol_tot;
Thread *t;
cell_t c;
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
volume = C_VOLUME(c,t);
temp = C_T(c,t);
if (temp < tmin || tmin == 0.) tmin = temp;
if (temp > tmax || tmax == 0.) tmax = temp;
vol_tot += volume;
tavg += temp*volume;
end_c_loop(c,t)
tavg /= vol_tot;
printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg);
begin_c_loop(c,t)
temp = C_T(c,t);
C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin);
end_c_loop(c,t)
Old   October 16, 2008, 06:50
Ananda Himansu
No idea. I do not know the Fluent UDF language or C (being a Fortran person). However, I must ask, does Fluent somewhere initialize vol_tot to zero?
Old   October 17, 2008, 11:22
Anderson
The solution regarding the following error for execute on demand can be solved by the following steps:
1)Read your case file,check your grid 2)Add the source file to your UDF to be compiled. At the compilation, build and load the the source file. 3)Set your user defined memory to 1. 4)Initialized your solution and performed 1 iteration. 5)Load again the UDF source file in User defined function. 6)Now try execute on demand.
Old   October 17, 2008, 12:48
Ananda Himansu
That is good to know.
I still do not understand why you do not have something like
real vol_tot = 0.; real temp, volume;
instead of
at the beginning of the udf. But perhaps the initialization of vol_tot is being performed in step 3) of your usage protocol.
segmentation violation: define on demand spring FLUENT 1 July 27, 2012 14:37
execute udf in ss & transient simulation hosseinhgf FLUENT 0 December 1, 2010 09:41
On demand UDF error RS FLUENT 0 May 10, 2007 13:54
execute on demand pourak FLUENT 0 April 20, 2007 07:24
Execute Commands from input file Greg Z FLUENT 1 May 24, 2006 17:56
