LES test filtering
Old   October 14, 2008, 08:32
Default LES test filtering
keith
Hi all,
I am doing a simple open channel flow simulation, with shear defined by the log law as the bottom boundary. The domain was descritized with a finite volume staggered grids. When test filtering for the Dynamic LES SGS, particularlly at the bottom boundary for the terms |S|Sij, what boundary conditions do we provide to close the equations?
Old   October 14, 2008, 15:46
Default Re: LES test filtering
Harish
If you do not resolve the viscous and buffer layer, you need to be careful with the kind of boundary conditions that you employ for the model. I would suggest you to search for review articles on LES by Moin. He has a detailed discussion on the implementation of the BC.
Old   October 14, 2008, 16:04
keith
Thank you Harish for the reply. Can you provide me with the reference/paper title that you meantioned? thank you in advance.
Old   October 14, 2008, 17:11
Harish
@article{moin2002ale, title={{Advances in large eddy simulation methodology for complex flows}}, author={Moin, P.}, journal={International Journal of Heat and Fluid Flow}, volume={23}, number={5}, pages={710--720}, year={2002}, publisher={Elsevier} }
@article{cabot2000awb, title={{Approximate Wall Boundary Conditions in the Large-Eddy Simulation of High Reynolds Number Flow}}, author={Cabot, W. and Moin, P.}, journal={Flow, Turbulence and Combustion}, volume={63}, number={1}, pages={269--291}, year={2000}, publisher={Springer} }
Old   October 14, 2008, 18:05
keith
Harish,
thank you very much. I will look into both the papers.
calculation of test filter quantites for desired parameters(equations) in les mrn FLUENT 0 July 15, 2010 06:04
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
LES Test Filtering Nabi Main CFD Forum 0 October 27, 2008 22:34
