On the vorticity contour around circular cylinder
Old   September 1, 2015, 12:27
Default On the vorticity contour around circular cylinder
Neo
9mile is on a distinguished road
Hi all.
Recently i've simulated the2-D flow past a circular cylinder.
But i got some strange picture from the vorticity contour.
With the zero of vorticity, the contour display wiggles in the whole domain.
Without zero, the picture looks good.
I don't know what happen.
I attached both pictures.
So, please take a look and give some opinions
Is there someone who experienced same situation ?
Any comment or advice is welcome.
9mile is offline   Reply With Quote
Old   September 1, 2015, 12:38
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
It's quite normal that plotting iso-vorticity = 0 you get a sort of wiggles...
the best you can do is working with double precision and using a low threshold in your iterative solvers but that would not always work better.
The important issue is to check the flow field variables
FMDenaro is offline   Reply With Quote
Old   September 1, 2015, 22:35
Neo
Hi FMDenaro,
Thank you for a quick reply.
I am going to try to post-process with double precision.
But if it would happen same result and it is quite normal,
Can i proceed with excluding the iso-vorticity=0 region ?
What does it mean to check the flow field variables?
Pressure and velocity show good results in quantitatively and qualitatively way.
I can't find the wiggles on zero-region for the pressure and velocity.
Even both flow variables satisfied the convergence criteria.
Regards.
Old   September 2, 2015, 04:14
yanbin
yanbin is on a distinguished road
Just try to set a smaller limit of vorticity to display,such from -5 to 6.
yanbin is offline   Reply With Quote
Old   September 2, 2015, 04:22
Originally Posted by 9mile View Post
Hi FMDenaro,
Regards.
I suppose you compute the vorticity from the velocity field, thus the discrete derivative causes possibly errors, furthermore the "zero" value is something that the isolines interpolate from small values, for example think about what would happen interpolating between 10^-6 and -10^-6 (that wolud be zero in a single precision).
Old   September 2, 2015, 11:47
Neo
Thanks for reply.
Dear yanbin, it still doesn't work despite i adjusted the limit.
Dear FMDenaro,
As you mentioned, i calculated the vorticity from the velocity field.
And it is true that small variations make the iso-lines of zero with the wiggles by interpolating single precision values between the nodes.
But i am not sure that it is possible to fix the wiggles only with the double precision.
If not, can i go with intentionally excluding the wiggles?
Regards.
Old   September 2, 2015, 12:20
Thanks for reply.
Dear FMDenaro,
Regards.
the key is understanding what wiggles mean...so check the magnitude, it should be very low, around zero.
However, you solve for velocity and pressure, therefore are such variables you really solve in the code to be checked
Old   September 2, 2015, 12:35
Neo
Ok, i got it.
Thanks.
3D vorticity contour shahzad_munir Main CFD Forum 0 May 1, 2014 03:34
vorticity contour achyutan OpenFOAM Post-Processing 0 April 29, 2014 09:09
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM Running, Solving & CFD 0 November 2, 2013 05:32
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
