Can people model 2 phase fluid flow (air water) in 6 mm tubing?
Old   August 25, 2015, 15:20
Default Can people model 2 phase fluid flow (air water) in 6 mm tubing?
Brian White
gaiatechnician is on a distinguished road
So, Just wondering if people can simulate the thing in my video. Airlift pump with and without the constriction. I develop very low pressure airlift pumps as a hobby and as a challenge. I use them in my garden to pump water (usually to circulate it to plants from a bucket up so it drips down through the soil. I think this grows things faster). One thing I did was test the limits of how high these could pump with very low pressure to power them. For instance I was able to pump 1.5 meters high with just 0.15 psi air pressure. In every really high pumping application I needed a constriction about 20 to 30 cm behind where the air was inputed to prevent a back and forth motion that wasted energy. I have never seen anything like it in designs from other people but it definitely works really well. I have used it for a few years now. Can anybody model this to explain it? (I have my own explanation but nothing, except intuition and observation to back it up). I did a video of one of my airlift pumps recently to demonstrate the effect. https://www.youtube.com/watch?v=LC41OjIcKow I used a little tap to close off the water in this video but usually I use a little length of aquarium air tubing to make a constriction. Thanks for the modeling help if anyone gives it a go. Brian White Victoria, BC Canada.
gaiatechnician is offline   Reply With Quote
2 phase flow, airlift pump, plug flow, slug flow
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Two phase flow of air and water with two inlet amin.shuvo FLUENT 5 August 18, 2015 06:49
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
How to go about modeling injection nozzle two phase flow in FLUENT? skonda2 Fluent Multiphase 0 March 17, 2015 08:52
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
