Design Process: Turbine Inverse of Pump?
Old   August 18, 2015, 08:27
Default Design Process: Turbine Inverse of Pump?
Stephen
mr.hardcore.engineer is on a distinguished road
Hey everyone,
Perhaps a silly question, but can anyone confirm that the design process is similar between a pump and a turbine?
I've been using CfTurbo's axial pump design flow. I've entered in my desired operating RPM, head, and other parameters. It creates a very nice looking set of pump blades via some meanline calculations. If I simply pump water in at the mass flow rate, can I expect the same response curve?
They do have a turbine design flow, however, it seems to only support gases. There is no option for water and it seems to want to work with compressible flow only. I tried to enter in parameters for water, but it wants to know the ideal gas behaviours, etc.
Any insight from the experts?
thanks! -
Stephen
mr.hardcore.engineer is offline   Reply With Quote
Old   February 25, 2016, 12:20
Luke
aerospace84 is on a distinguished road
yes the pump work roughly fine also in turbine mode, the major problem will be the impeller trailing edge that will effect the efficiency and the QH curve, lowering the value for both.
then often when you design directly a pump thinking for a reverse operation, you will obtain something that will work so and so in both the behaviours.
aerospace84 is offline   Reply With Quote
Inverse design with SU2 gina07 SU2 Shape Design 2 March 25, 2015 10:01
Radial Turbine Design for Turbocharger sagch ANSYS 2 January 16, 2015 13:16
Radial turbine design and analysis Renhick FLUENT 1 December 18, 2012 11:57
use of cfd in process equipment design pramod Main CFD Forum 0 August 14, 2002 11:06
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
