Internal Energy equation in viscous compressible floe equations
Old   August 17, 2015, 16:34
Default Internal Energy equation in viscous compressible floe equations
Mihir Makwana
mihirmakwana6 is on a distinguished road
How can I use FVM to discretize the term
sigma : D
in the internal energy equation
http://i.imgur.com/3RaYm5p.jpg
where
sigma and D are given by
http://i.imgur.com/6K65Lih.jpg
I am not able to expand the term sigma : D
Please help.
Thanks in Advance
- Mihir
mihirmakwana6 is offline   Reply With Quote
Old   August 17, 2015, 18:03
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
If you want using a FVM, you have to recast the equation in the divergence form and integrate over a finite volume each term.
Using the expression of sigma, the term D:D you get is a scalar function that appears as volume source
FMDenaro is offline   Reply With Quote
Old   August 18, 2015, 02:21
Mihir Makwana
sir, if i use tensors then sigma : D gives
http://i.imgur.com/UmzDCrI.jpg
How do i convert this equation to divergence form ?
Old   August 18, 2015, 03:45
Mihir Makwana
sir say i split D
then one of the term is
http://i.imgur.com/zkbee0D.jpg
here Tau is sigma
so the 1st term on r.h.s is in divergence form but the second is not
Old   August 18, 2015, 04:13
no, you do not have all terms in te internal energy equation in divergence form...that respects the physical fact that such energy form does not have a conservative formulation. The term D: D is a pointwise source term, you have to integrate over the local volume in a FVM and discretize the volume integral.
If you want to work with a fully divergence form then you have to adopt the total energy equation
Old   August 18, 2015, 05:58
Mihir Makwana
ok.
1) As i am using FVM, i cannot integrate the second term in RHS of
Right ??
or is there a way I can integrate it over the C.V
2) what is D: D ?
Old   August 18, 2015, 06:02
you can always integrate each term of the equation over a finite volume...when the term is in divergence form you can apply Gauss and get the surface integral of the fluxes, conversely the integral to discretize remains the volume integral (see for example the book of Peric & Ferziger).
D: D is nothing else that the double dot product between the symmetric velocity gradient
Old   August 18, 2015, 06:04
Mihir Makwana
1) ok.
2) but i need to find sigma : D and not D : D
Old   August 18, 2015, 06:11
sigma: D is nothing else that a product by an isotropic tensor (I: D) added with D: D
for brevity I disregarded the coefficients
problem on energy and flow equation solving separately preetam69 FLUENT 2 July 30, 2013 22:08
k-e turbulence model and energy equation Blob Main CFD Forum 0 May 29, 2009 09:35
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 02:54
question about energy equation zhou FLUENT 0 February 24, 2004 00:55
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
