Initial condition for unsteady calculation
Old   September 30, 2008, 15:09
Default Initial condition for unsteady calculation
Jianglan
If we are trying to simulate a flow which,despite having boundary conditions that are constant in time, still is expected to exhibit unsteady behaviour. In choosing an initial condition for the unsteady calculation, would it make sense to use the steady solution(presuming one can be found)?
Thanks
Old   September 30, 2008, 19:26
Default Re: Initial condition for unsteady calculation
Harish
The flow would eventually become unsteady due to the numerical errors but depending on the problem being studied the time taken for reaching unsteadiness might be long if you use a steady solution. Try using a perturbed solution of the form
U_i=U_s+C*U_s*sin(w*x)......
where C you can use between 0.05-0.2 and w is the frequency which you can compute based on the domain size or you can impose arbitrary frequencies.
Hope this helps.
Old   October 1, 2008, 23:58
Jianglan
Thank you very much. I grasped the general meaning, however I GOT LOST in the Equation (the perturbed solution). Is there any book or website you may recommend? Thank you.
Kind Regards
Old   October 2, 2008, 03:47
Harish
There was a discussion on this topic in the context of channel flow in the current forum. search in the forum and you would find it.
Old   October 6, 2008, 00:55
Jianglan
Thanks Harish. ^_^
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 03:18
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 13:30
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 06:36
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
