codes for water hammer on pipe flow
Old   September 28, 2008, 02:43
Default codes for water hammer on pipe flow
park
hi all,
i am new to fortran. i need to write program for pipe flow with water hammer effect.
assume a model consists of reservior with one pump sucks the water from the reservior. a check valve is installed ahead of the pump. And the water is circulated, when the pump trips the pressure transients will occur. Can any one give the idea of how to strat write the codes( in fortran or matlab) by using finite differnce method.
thanks in advance for ur reply.
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 07:58
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
