Pipe flow simulation
Old   September 23, 2008, 00:35
Default Pipe flow simulation
James Lam
I'm totally new to Ansys ICEM CFD and CFX, and there are some questions I would like to ask. I'm using Ansys ICEM CFD v11 and CFX v11.
I'm going to simulate pipe flow, and I have created a "solid column" model with SolidWorks and saves it as IGES file.
Then I import this geometry to Ansys ICEM CFD by "File -> Import Geometry -> STEP/IGES"
After that, I generate the mesh by going to the "Mesh" menu and select "Compute Mesh", and let the program to do all the settings for me.
However, I do not know how to export the mesh to Ansys CFX to continue the simulation.
Could anyone tell me all the steps?
Thanks, Lam
Old   September 23, 2008, 09:24
Default Re: Pipe flow simulation
gallon
export the mesh to cfx: output > select solver, then choose the solver you want to use. BTW:if you want to generate structural mesh,the steps you generate mesh is not so good. please read the tutorial of ICEM.
Old   October 9, 2008, 08:12
Default Re: Pipe flow simulation *NM*
mawia adam.m
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 05:04
Domain for Pipe Flow Swarup FLUENT 0 September 29, 2005 00:25
stepped pipe flow Tom Cloutier Main CFD Forum 0 April 20, 2003 14:19
