September 22, 2008, 18:34 |
calculation of y+ value
I am simulating a sonic underexpaned jet. The flow expands up to M = 2.8 and then there is shock. Well my question is about grid generation, in the formula for yplus=yu*/nu, (nu= viscosity), What should the u* value be based on M = 1 or M =2.8? Also is assuming u*=U/30 a good choic for u*? where U speed of sound or based on M = 2.8.
Thank you very much. |
September 23, 2008, 15:41 |
Re: calculation of y+ value
friction velocity (utau/u*) values are usually calculated from some initial runs and by computing the wall shear stress. Try to run your code with different levels of grid refinement for around one period of the relevant time scale and computed yplus.
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 10:37 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 09:46 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 05:20 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 09:19 |
