how to solve a steady problem explicitly
Old   September 20, 2008, 18:30
Default how to solve a steady problem explicitly
meda
Dear all, I am a little bit confused how I can solve a steady-state problem EXPLICITLY. do I have to write code for an unsteady situation and then give a long time?
thanks. Meda
Old   September 21, 2008, 06:39
Default Re: how to solve a steady problem explicitly
Paolo Lampitella
Yes, until the time derivatives will be 0
Old   September 21, 2008, 11:55
ztdep
yes, you need to specify a time step, and it must satisfy the stability condition, then let it run until the difference between two consecutive time step is very small.
Old   September 22, 2008, 07:30
Bart
In a steady state solution you can use local time stepping. Each cell progresses at it's own CFD criterium. As the solution is steady state the final converged outcome does not depend on the (local) timestep. This can significantly decrease your CPU time. In normal unsteady problems (explicit) your timestep is determined by the smallest cell with the largest velocity (via CFL criterium giving you a small overall timestep).
Bart
Old   September 22, 2008, 15:36
meda
hi Bart.how can I define the local time stepping for each cell? doesnt it take more time to compute the criteria for each cell than to define a genaral criteria?
Old   September 23, 2008, 04:27
Bart
I general criteria also requires you calculate a CFL timestep for every cell in between timesteps. I mean, how do you determine your timestep now and would it really make a big difference? However if your velocity scales and cell sizes in your domain vary only slightly then it may not make sense to use local timestepping.
Old   September 25, 2008, 07:53
bkjohn
You can also employ local-preconditioning, which alters PDE such that all waves travel at an equal speed, thereby maximizing the minimum local time step (local time step is limited by the slowest wave speed of the PDE system). See this van Leer's paper --> Download at http://citeseerx.ist.psu.edu/viewdoc...10.1.1.43.8861
Good luck,
bkjohn
Help me to solve a basic heat transfer problem maysmech OpenFOAM Running, Solving & CFD 3 April 2, 2010 08:14
convergence problem in 3D steady state, laminar flow in a bath vajiheh FLUENT 0 July 10, 2009 13:18
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 17:34
transient problem run in steady state luigi FLUENT 4 March 13, 2008 07:54
use of MAC method to solve sloshing problem. S.R.SAHI Main CFD Forum 1 April 15, 1999 23:28
