Transition Modeling using CFX4.2
Old   November 24, 1999, 15:07
Default Transition Modeling using CFX4.2
Athar
I just want to know whether anyone has done transition modeling for separated flows using Low-Reynolds number K-W in CFX 4.2. I tried doing it but the model is not designed to handle transition problem. Some of the coefficient in the source term have to be modified ( Wilcox 1998). This can be done using USRSRC but I just want to know whether anyone has tried doing it successfully for separated confined flow problems. Thanks Athar
Old   November 24, 1999, 16:02
Default Re: Transition Modeling using CFX4.2
Jonas Larsson
Transition modeling in separated flows... that sounds too difficult for a two-equation model. My experience is that on real-life applications two-equation models are not capable of predicting transition correctly, although they in theory could predict by-pass transition (transition caused by diffusion of turbulent energe from the free-stream into the boundary layer). I've used both the standard k-w model and the "transition optimised" k-w model trying to predict transtion on turbine blades, none worked well. Haven't used CFX though.
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 12:49
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Transition modeling using K-w Athar CFX 1 November 25, 1999 02:40
