limiter for gradient reconstruction FVM
Old   September 18, 2008, 04:59
Default limiter for gradient reconstruction FVM
harry
Hi All,
I am puzzled by some methods for gradient reconstruction in literature. For Gauss based method, two general methods can be found. The first one is given by Ferziger and Peric's book, gradient is calculated by a iterative method based on gradient(p)= sum[(0.5*(p1+p2)+gradient(p)*x)*sx/v]. The second one can be found in the online-help of STar-CCM+
http://www.kxcad.net/star-ccm/online...utation-5.html
In the second one, a limiter is introduced. According to S. R. Mathur and Murthy (1997), A PRESSURE-BASED METHOD FOR UNSTRUCTURED MESHES, heat transfer, The formula is likely expressed as gradient(p)=sum (0.5*(p1+p2)*sx/v*limiter).
My questions are
(1) my understanding of the second one is correct or not? iterative calculations are not necessary if limiter is there, right?
(2) the first one could exceed the maximum and minimum of the neighboring cell centroid values, right?
(3) which is better?
Your hints would be greatly appreciated.
Cheers,
Harry
Ultimate Flux Limiter gentela Main CFD Forum 1 August 2, 2016 21:55
slope limiter and flux limiter ?? Ameya J Main CFD Forum 1 June 13, 2011 13:05
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
