Mesh size
Old   September 17, 2008, 12:40
Default Mesh size
Ramesh.K
Hi all,
can any body tell me the criteria to determine the mesh size and time step size in hand before solving the problem
is there any estimate where in we can say that we can go till this paritcular size for mesh and time step.
how are these dependent upon the initial and boundary conditions.
we know that high frequiencies are always solved on fine mesh sizes and so we determine once we know the highest frequency in the problem.
thanks in advance
Old   September 17, 2008, 15:02
Default Re: Mesh size
mettler
I always did a grid check. I got a solution that I was happy with, and then I would increase the mesh count and see if the answer was the same or at least within some %, and then I would also decrease the mesh size and check the answer again. If the answered changed substantially when I increased the mesh size I knew something was wrong and would increase the mesh count again and see how that answer compared. You can visually show this in a graph of mesh count v's answer..you will flat line after you find the least amount of cells
Old   September 18, 2008, 01:40
Ramesh
Hi
Thanks for the reply
but thats a crude way of setting the size.
in first hand can we try to predict by knowing the frequency range ofthe problem under cosideration.
Old   September 18, 2008, 06:58
Anton Lyaskin
If you're running a non-steady simulation (i.e. real transient or pseudo-transient), than your mesh size and time step are linked together via Courant number. Though there are strict restrictions only explicit schemes, which are not so widely used, even for implicit scheme putting a Courant number above 500...1000 will make no good.
Another limitation comes from y+ if you do a turbulent simulation (and if it's not DNS). This can give you the size of near-wall cells. And you can actually derive the size of all other cells from mesh quality considerations like aspect ratio limit and also the fact that most differencing schemes doesn't perform well if two adjacent cells differ in size more than 1.2...1.5 times.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Gambit Unstructed (Tet) Mesh - size control newbie FLUENT 3 August 26, 2008 12:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to decide the mesh size? echo Siemens 1 May 23, 2006 06:34
