IGES Solid Model for ICEM Tet Mesh
Old   September 16, 2008, 20:25
Default IGES Solid Model for ICEM Tet Mesh
Samer
I have been iterating with modeler person using CATIA 5 to make me a fairly complex 3D solid model...
When I check the model in ICEM 11.0 and create topology, I get some yellow and blue curves (red being good). I can make a tet mesh using default settings, but it doesn't pass the mesh checker and definitely won't work in Fluent.
Am I stuck trying to get the modeler person to improve the quality of the solid model?
Thanks in advance, Samer
Old   September 17, 2008, 13:33
Default Re: IGES Solid Model for ICEM Tet Mesh
Charles
There's a lot you can do in Icem to clean up the geometry topology manually. The first thing is to look at the tolerance when building the diagnostic topology. Then start manually deleting surfaces that shouldn't be there and add surface patches to close holes and cracks. You don't want to do this multiple times, but if it is more or less a once-off, it is practical to do it this way. Sometimes it doesn't need much clean-up (i.e. some blue and yellow edges are still left) before you get a mesh that work. It is not a robust process, but at least you can get the job done.
I've worked with designers and draughtsmen who have fed me perfectly clean solid models, and those are a lot easier, obviously. But also with models that look like they have been drawn with 10 mm crayons. With some work, you can normally get these patched well enough in Icem to get a reasonable tetra grid.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Turbulence model and mesh size Julien Pralong FLOW-3D 1 August 9, 2010 14:18
k-e model and mesh sensitivity raj calay Main CFD Forum 13 July 28, 1999 16:48
