Length of sonic nozzle
Old   September 15, 2008, 14:55
Default Length of sonic nozzle
oe
Hi I need to calculate the length of a sonic nozzle, with exit radius = 12.7 mm(0.5 inch). This is the only information given. assuming gamma=1.4 There are relations for the contraction ratio Ax/At in terms of Mx anf gammma. Here Ax= area at any location before the throat At= area at throat Mx= Mach number at location x. I picked an arbitrary value for Mx = 0.2 and got a value for Ax, but how do I get the length of the converging section. Any help is appreciated Thank you.
Old   September 16, 2008, 09:49
Default Re: Length of sonic nozzle
ag
Length is arbitrary - it doesn't affect the flow behavior. That's why only the area ratio is expressed in terms of Mach number. If you consider viscous flow there will be a small effect due to boundary layer growth, but I am assuming that you are looking only at inviscid flow.
Old   September 16, 2008, 20:28
shuo
If it is a sonic nozzle then the one dimensional isentropic analysis should suffice - ignoring viscous effect such as the boundary layer. If it is a de-Laval type nozzle then as along as the divergence angle of the nozzle isn't so great as to induce flow separation the 1D analysis should still hold.
Shuo
boundary layer thickness in super sonic nozzle alikami Fluent UDF and Scheme Programming 0 February 19, 2011 07:37
boundary layer thickness in super sonic nozzle alikami FLUENT 0 February 19, 2011 07:31
calculate nozzle length oe Main CFD Forum 0 July 30, 2008 15:06
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
super/sub sonic flows in laval nozzle Kalyan Siemens 4 August 17, 2005 18:58
