2nd order conservative schemes
Old   September 15, 2008, 01:05
Default 2nd order conservative schemes
taw
Dear fellows,
I want to use second order conservative schemes, especially for the k.e. therm that would keep the code stable or realizable enough, for DNS stability simulation of a high Re flow. The main reason to go for 2nd order is to keep my present 2nd order code intact, i.e. instead of going to the 4th order scheme.
Being new to these idea and after skimming through Morinishi, 1998 I kind of got the impression that for 2nd order schemes to be conservative in the kinetic energy sense, one should use a uniform grid. Do you think I got the idea right.
Or is there another way around to tackle this problem, without going for the 4th order scheme.
My code use a collocated grid in primitive variable formulation in Cartesian coordinate system only. I plan to simulate a simple geometry, a flat plate.
Regards
TAW
Old   September 16, 2008, 08:05
Default Re: 2nd order conservative schemes
Andrew Clarke
I had a similar problem in my work before. I just reduced the underrelexation factors in the Solution Controls panel for appropriate factors.
In my case, i got pressure-correction divergence reported in second order solving but when i reduced the pressure underrelaxation to 0.2 and momentum to 0.4, i could get stability quite well but solutions took more iterations. The selection of underrelaxation factors is a matter of trial and error.
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 13:29
1st order vs 2nd order ken FLUENT 8 March 14, 2013 04:43
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 09:12
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 01:31
