Best option to determine motion of an object due to internal fluctuating flow. |
July 22, 2015, 22:30 |
Ahmed Jalal
Rep Power: 11 |
All,
I am relatively a beginner in CFD and would need help setting up a problem. I am modelling a valve chatter problem in 2D of a check valve (Star CCM+). Basically, there is a ball inside a valve that moves randomly due to the pressure build up due to fluctuating inlet velocity. Of course, there will be mesh morphing/deformation. Assuming I know the inputs and outputs of the problem. What is the best approach to defining the ball motion. Is it a user code, field function...? I would really appreciate any help my way. Ahmed Jalal |
field function, internal flow, user code, user defined functions |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
