Premixed combustion
Old   July 21, 2015, 15:18
Default Premixed combustion
george
george_brickhouse is on a distinguished road
Hi everyone,
I am modelling combustion of methane-air premixture (1:10 by volume) inside the enclosure with internal pressure 7 kPa and nitrogen gas inside. Models: EBU, k-e standard, radiation DO.
I have 2 cases:
1. enclosure is sealed, Ideal gas inside.
Result: combustion proceeds, pressure in enclosure rises adequately, initial flame temperature is adequate, but it drops with time (by about 10% within 2 min). This is not understandable for me - pressure and ambient temperature grows but the flame temperature drops.
2. enclosure has pressure outlet with gauge pressure 7 kPa. Incompressible ideal gas is in enclosure.
Result: combustion proceeds, pressure in enclosure almost does not rise (this is reasonable), initial flame temperature is adequate and it does not drop.
What to do with compressible problem? Why flame temperature drops?
I hope somebody could help me. Thanks.
George.
george_brickhouse is offline   Reply With Quote
Old   July 22, 2015, 08:02
Lucas
Edeluc is on a distinguished road
Hello George,
Taking your stated boundary conditions into consideration you are having a rich combustion environment (because the stoichiometric Air-to-Fuel ratio for methane is about 17.2).
The EBU model in it's original form has difficulties in dealing with rich/lean combustion. Therefore I would suggest to change to a different combustion model if possible. If you only have the original EBU available I would change to a stoichiometric mixture and see if the temperature drop still occurs.
Furthermore could you explain what you mean by "nitrogen gas inside"? Do I understand correctly that you have your premixed air/methane flame burning into an enclosure with nitrogen? (meaning some sort of jet flame).
Regards,
Lucas
Edeluc is offline   Reply With Quote
Old   August 25, 2015, 13:02
george
Thank you Lucas.
By "nitrogen gas inside" I meant that the surrounding gas is nitrogen. Yes, you are right, the ch4-air mixture burns within the sealed enclosure.
What model would you recommend to switch to?
Regards,
George
combustion, compressible gas, flame temperature, premixed combustion
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 14:07
Species computation in premixed combustion zcarral FLUENT 0 July 25, 2013 03:46
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
Premixed Combustion IS FLUENT 3 July 9, 2010 21:22
Non-adiabatic Premixed combustion through scriptin Mahesh FLUENT 0 March 31, 2007 09:19
