Array Comparison in Fortran 90/95
Old   September 11, 2008, 11:50
Default Array Comparison in Fortran 90/95
M Malik
Hi FORTRAN 90/95 Users: Want to know some efficient way of comparing two or more large size arrays in FORTRAN 90/95. Thanks
Old   September 11, 2008, 12:10
Default Re: Array Comparison in Fortran 90/95
M Malik
To be a little more specific: The arrays could be of different lengths and want to compare them for duplication. -Malik
Old   September 11, 2008, 13:55
Jed
Oh, they are integer arrays representing sets? You want to determine what integers appear in both arrays? If the range of possible values is known and reasonable, you can mask a bit-array. Otherwise, just sort the arrays.
Old   September 11, 2008, 14:41
M Malik
Thanks Jed. Yes, I have integer arrays. The range is not known all the time. Comparison by sorting turns out to be very time consuming. Some other suggestion, please!
Old   September 11, 2008, 15:14
Jed
Keep the arrays sorted or partially sorted. If you don't sort, you end up with O(n^2) which is much worse. A radix sort shouldn't be that bad. Where do these arrays come from? How big are they? I assume you solve equations at some point? Or is this for mesh manipulation? Would a different data structure be better?
An unknown array definition in fortran morteza08 Main CFD Forum 0 June 20, 2011 05:32
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
largest one-dimensional array in fortran 77 yfyap Main CFD Forum 20 November 2, 2008 22:57
Compaq Visual Fortran - array, debug CFD Student Main CFD Forum 0 May 10, 2008 08:59
Array Visualizer in Visual Fortran Krishna Main CFD Forum 0 December 6, 2004 04:23
