July 21, 2015, 05:27 |
Rubber Valve (Relief valve)
James
Rep Power: 11 |
Hello guys,
We are developing a product, and need to do some simulations to validate it. The product is like a small tube with a rubber valve that will work like a relief valve, i.e. it will deform after it reaches a set pressure allowing the fluid to pass through. Is it possible to simulate this with CFD? I've been looking for a way to simulate a elastic flow-induced deformation, but I still haven't come across anything useful so far. |
July 21, 2015, 07:14 |
James
Rep Power: 11 |
It would be, roughly, something like this
July 21, 2015, 09:00 |
Rep Power: 13 |
Hi James,
One of the ways I could imagine doing this would be a full 2-way FSI (depending on the detail or scope of analysis), you could refer to Tutorial 23 of CFX to get some idea..even if you're not employing CFX-ANSYS, searching for that tutorial would help elaborating the approach.. IMO another simpler way of doing this could be a 1-way FSI.. to begin with, establish the pressure loads of the Fluid and transfer them to Structual module (using fluid-solid BC) and observing the structural deformation.. if that deformation is to be studied further in presence of passing flow then the deformed shape could be modeled as a new geometry and separately evaluated in CFD... just an opinion & from what i could quickly comprehend.. cheers.. |
July 22, 2015, 07:27 |
James
Rep Power: 11 |
Thanks, Fresty.
I will have a close look at it to see what can be done this way. |
deformation, deforming, pressure, relief, valve |
Modelling an initially closed valve which a fluid opens | siw | CFX | 1 | April 26, 2014 07:32 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 02:31 |
Pressure relief valve | carno | Main CFD Forum | 2 | January 13, 2009 01:06 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 15:09 |
