July 17, 2015, 15:51 |
problem simulating an advection equation
I am struggling with a very simple problem for the past few days. I won't be surprised if the answer is terribly simple. I want to simulate a simple advection equation: du/dt + U du/dx =0 u(t=0) = sin(x) u(x=0, x = pi) =0 I wrote a simple finite difference upwind spatial discretization with explicit time advance = - t .U/ x ( - ) The problem is that the amplitude of the waves shrinks as time goes by, while I expect the wave shape is preserved and only translated to the left (assuming U>0). (see figure 1) https://www.dropbox.com/s/nrvadimqenf2uxx/1.bmp?dl=0 Alternatively, I can use a more sophisticated scheme such as beam_warming. The shrinking problem here is fixed, but I get some wobbling noises. see figure https://www.dropbox.com/s/ric984qv73xvh9w/2.bmp?dl=0 Any idea/explanation/suggestion/comment would be great. Thanks for reading. |
July 17, 2015, 16:01 |
Filippo Maria Denaro
Rep Power: 73 |
what you discovered is the well known presence of artificial viscosity in the first order upwind method....I suggest a carefull reading of a good text of CFD to study the theoretical reasons by means of the modified equation.
higher order schemes are not monotone and can generate wiggles |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Use advection step and Dispersion step to solve advection diffusion equation | cooljd | Main CFD Forum | 0 | October 15, 2012 15:44 |
Problem with a leapfrog scheme for wave equation | Shiranui | Main CFD Forum | 0 | June 22, 2010 09:19 |
continuity equation | Rafal | Main CFD Forum | 4 | November 29, 2006 09:27 |
Energy equation convergence problem | Reza | Main CFD Forum | 0 | August 27, 2003 13:09 |
