Problem with XFlow
Old   July 13, 2015, 17:46
Question Problem with XFlow
Gerardo Jiménez
GJimenez is on a distinguished road
I'm trying to validate XFlow using the Validation Guide and i'm having problems with the NACA 0012.
The program gives me a CD over 1.5 and postprocessing Vorticity gives me this:
Near the wall gives me some vortex generating a lot of drag. I don't know how to get rid of them. I follow all the steps in the Validation Guide.
Can anyone help me with this?
GJimenez is offline   Reply With Quote
Old   July 14, 2015, 13:36
Giuseppe Trapani
Yplus is on a distinguished road
Hi Gerardo,
From a quick look at your attached vorticity contours it looks like the number of points you are using to discretise the NACA0012 is not enough to give an accurate leading edge. This leads to a quite sharp LE and that explains the high vorticity regions you see. I would suggest to increase the number of points you are using when generating the airfoil in XFlow.
Yplus is offline   Reply With Quote
Old   July 14, 2015, 14:33
Gerardo Jiménez
Hi Giuseppe,
I used the Geometry generator from XFlow, I'll create the geometry in other CAD software and try it.
Thanks a lot!
Old   July 14, 2015, 19:56
Gerardo Jiménez
I'm having the same problem, now the CD is .74, still high.
I'm analyzing the NACA 0012 at Re 500.
With resolved scale of 2.56 m
Adaptive refinement
Target scale .005m
Wake REsolution .005m
I tried with a higher resolution (.01m) and the problem was lower.
Old   August 3, 2015, 09:45
Javi
FJSJ is on a distinguished road
Hi Gerardo,
can you share your geometry and .xfp file? I will have a look!
Are you using convolution for visualizing? How many points are you using to define the NACA section? (I assume you are using Create NACA (4 digits) tool from XFlow)
FJSJ is offline   Reply With Quote
Old   August 12, 2015, 13:03
Gerardo Jiménez
Originally Posted by FJSJ View Post
Hi Gerardo,
I had help from XFlow and my problem was solved, they send me the .xfp file.
But I tried with another airfoil and accidentally I put a Target resolved scale of .14 and the results where ok, but when I put the target at .005, the airfoil generate a lot of turbulence and a lot of errors.
Its bad to have a target as little as .005?
drag coefficient, validation, vorticity, xflow
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
