Nusselt number evaluation
Old   July 12, 2015, 08:48
Default Nusselt number evaluation
roberto
robro92 is on a distinguished road
hello everyone; i have to evaluate the Nu number for a triangular duct in turbulent flow with liquid water. We imposed the Twall , thus we calculate the heat flux q [W/m2] on all the pipe length. Our doubt is about the bulk mean temperature, h=q/(Twall-Tbulk). Which Bulk mean temperature should I use?? We use the bulk temperature at the outlet of the pipe.
robro92 is offline   Reply With Quote
Old   July 13, 2015, 03:43
JulianP is on a distinguished road
This is not a problam, actually. You just have to choose one (e.g. the inlet temperature) and stick to it.
If you want to be safe, you can always talk about the "Nusselt number calculated using the inlet temperature".
JulianP is offline   Reply With Quote
Old   July 13, 2015, 04:28
roberto
Thanks a lot ! However we solved the doubt..we used the bulk mean temperature close to the outlet, because we have fully developed conditions only there ( at the beginning we have the entry region). So we isolate a small volume there in cfd post
bulk mean temp, nusselt calculation
Nusselt number calculation in Fluent Sharadkumar Yeri FLUENT 52 May 29, 2019 07:29
Nusselt number 4.36 validation in a tube in constant heat flux situation QustFelix FLUENT 6 June 18, 2015 23:09
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Nusselt Number of the order of 35000 chinmay FLUENT 4 May 31, 2001 04:06
