September 3, 2008, 04:45 |
load a file.msh
whe I try to load a .msh file appears this message:Error read face.... Reading Faces:failed while read section What can it be? Originally I can load this mesh,but it presents a strange spacing along a part of the edge so I re-mesh my volume.
September 3, 2008, 07:02 |
Re: load a file.msh
Which software is it ? Fluent ???
September 3, 2008, 07:48 |
Re: load a file.msh
If the software is fluent, that may be because of an essential error in meshing the geometry. check the mesh again and repair it!
[OpenFOAM] How to load all <case>/surfaces/*/*.vtk at once into Paraview | holodeck10 | ParaView | 8 | November 22, 2019 17:52 |
How to model concrete slab in ANSYS and apply 2 million cyclic load. | jjc | ANSYS | 3 | April 12, 2011 04:47 |
moving load problem | aditi chauhan | ANSYS | 0 | October 9, 2010 04:47 |
Strarting load step number | KtoTo | Siemens | 2 | June 21, 2007 09:01 |
Using load vector for parallel partitioning | Kevala | FLUENT | 0 | May 1, 2001 12:11 |
