July 9, 2015, 19:16 |
Center of a mesh cell
Rep Power: 13 |
I have a structured mesh made of polyhedra (mostly hexahedra, and some pentahedra).
I am trying to find the "center" of each cell of this mesh. These are irregular polyhedra, where none of the sides/faces are 100% parallel. In the domain of meshing, when one speaks of the "center" of a cell, what type of center are they referring to? There's many different types of a "center." For example, there's spatial centers, which is just an average of all the nodes that make up the cell. There's center of volume, center of mass, etc.... |
July 10, 2015, 06:25 |
You probably mean 'unstructured'. However, the following paper:
http://www.dept.ku.edu/~cfdku/papers/1999-AIAAJ.pdf has the answer for arbitrary convex polygons/polyhedra. |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 06:39 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 20:54 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
