to simulate shock wave propagation with turbulence
Old   August 31, 2008, 04:54
Default to simulate shock wave propagation with turbulence
cfdgeek
hi
Can someone help me in describing the method to simulate shockwave with turbulence model (isotropy)
thanks in advance
Old   August 31, 2008, 17:47
Default Re: to simulate shock wave propagation with turbul
Harish
I am not sure of the exact problems that you are considering and the mach number that you might encounter so consider this as a general idea.
1. For shock capturing you can use either ENO(WENO) or other similar shock capturing schemes. 2. For turbulence part you need to look into the pros and cons of using each turbulence model and the ability of the model to give meaningful results for the simulations that you are performing.
Stationary Simulation of Shock Wave with Instationary Settings matten CFX 3 November 5, 2010 16:19
about local bump shock wave drag reduction fxzf Main CFD Forum 5 February 26, 2010 13:04
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
1D shock wave setup ant CFX 7 July 3, 2002 09:35
how to simulate wave? dingding CFX 3 July 18, 2001 12:20
