artifical compressilblity method for incompressibl
Old   August 28, 2008, 13:41
Default artifical compressilblity method for incompressibl
ztdep
Dear friends: I have some questions abou the artificial compressibility method for the steady incompressble flow. since the ACM add an unsteay term in the continuity equation. but i want solve a steady problem. so how to implement this method. would you please give me some detai about it. regards
Old   August 28, 2008, 16:45
Default Re: artifical compressilblity method for incompres
Harish
For steady problems, the time is a fictitious term and you march in time until the solution has converged. Look for papers by Kwak ( you may find it in NASA repositories too).
Old   August 28, 2008, 22:22
ztdep
Thank you very much for your feedback. Could you please give me the website of NASA repositories regards
Old   September 1, 2008, 05:16
momentum_waves
Dear ztdep,
Using the 'Penalty Method' is a nice, simple way to perform 'almost-incompressible' fluid flow calculations - marching forwards in time.
Take a look at the <www.freefem.org> site I mentioned in another message, or try the site <www.adthermtech.com/wordpress3> for some papers mentioning use of this method.
Regards, mw...
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 05:35
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 15:40
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 03:08
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 02:18
