Difference between simulation time.
Old   July 6, 2015, 07:49
Default Difference between simulation time.
Sam
sam181087 is on a distinguished road
Hi Guys,
I am solving for flow analysis in waterjacket in IC engine. I am studying, "effect of different turbulence model on flow physics in waterjacket".
I have simulated this with RNG k-epsilon and EARSM k-epsilon turbulence model. Results are more or less same only the simulation time for RNG k-epsilon is 22.4 hrs and EARSM k-epsilon is 14.3 hrs, both simulations are run for the same number of iteration on same parallel processes.
Can anyone tell me why there is so big simulation time difference???
Any guess?
sam181087 is offline   Reply With Quote
Old   July 6, 2015, 08:08
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by sam181087 View Post
Hi Guys,
Any guess?
linear solver
if you can report the time taken by pressure solver you will see that one takes longer to converge due to the reasons that viscosity (how it converges) to is different. You can also say report average and min max of viscosity to see the difference.
arjun is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
