Problem Encountered inLid Driven Cavity in Finite Volume Method with SIMPLE Algorithm
Old   July 3, 2015, 19:47
Default Problem Encountered inLid Driven Cavity in Finite Volume Method with SIMPLE Algorithm
Abdels83 is on a distinguished road
I have written my code in MATLAB and I need help from the forum on where things could be going wrong, my streamline plot appears not to be properly predicted and I am also not getting vortices on the corners of the cavity.
Please find code attached.
Please any help with code modification will be appreciated.
Thank you.
Last edited by Abdels83; July 4, 2015 at 10:44. Reason: I have updated the .m file and the code is now running. I also added the streamline plot for Reynolds number of 100.
Abdels83 is offline   Reply With Quote
Old   July 4, 2015, 07:55
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
your M-file did not run, you have some errors to correct (Lx is not defined when used, normres is not defined, etc)
FMDenaro is offline   Reply With Quote
Old   July 4, 2015, 10:46
Thank you Filippo, I have corrected the error and the code is now running. I also attached the streamline plot for Reynolds number of 100.
Many Thanks.
Old   July 4, 2015, 12:17
if you are using primitive variables you must debug your solution (u,v,p).
The streamlines are just a post-processing that can be affected by some factors.
However, the figure you attached shows a quite regular pattern for Re=100.
Use a fine grid (for example 100x100) to ensure Re_h =1 and check the velocity profiles (Ghia&Ghia paper).
finite volume method, lid- driven cavity, matlab, simple staggered grid
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
formulation of finite element&finite volume method ravindra FLUENT 0 June 27, 2007 13:04
finite difference method for navier-stokes problem dallybird Main CFD Forum 5 February 17, 2003 23:00
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 03:34
SIMPLE Algorithm & Conjugate Gradient Method Abhijit Tilak Main CFD Forum 7 March 20, 2001 01:01
