August 22, 2008, 12:45 |
Appropriate Numerical Scheme
I am trying to write a code and would like to know what would be the appropriate numerical scheme to capture the flow from Supersonic to Subsonic. We are looking at Mach 3 to subsonic and a mixed external as well as internal flow. Dr N M Sudharsan
August 23, 2008, 07:26 |
Re: Appropriate Numerical Scheme
There is a wide range of length and time scales involved in the range of speeds that you are proposing to your program. A pressure coupled solver will do well in the transonic to supersonic speeds, but what about the incompressible range You would need a SIMPLE type solver I do not think you can cover the whole range with a single scheme, check the commercial solvers available, FLUENT and like, they provide different schemes Good Luck
Numerical viscosity due to the MUSCL and HLL coulpled scheme | sonsiest | Main CFD Forum | 0 | May 23, 2011 16:37 |
problem about numerical scheme in LES. | libin | Main CFD Forum | 4 | July 1, 2004 05:32 |
The numerical scheme in LES? | Martin | Main CFD Forum | 1 | May 24, 2004 05:49 |
the numerical scheme for LES. | John S | Main CFD Forum | 2 | March 14, 2004 08:52 |
numerical scheme | ado | Main CFD Forum | 3 | October 12, 2000 09:20 |
