Reference pressure
Old   August 21, 2008, 12:41
Default Reference pressure
Fernando Herrera
Help,
Im coding a SIMPLE algorithm and I want to specify a reference value for the pressure correction (like Versteeg suggests).
In the book it says to select a point outside the solution grid, but my question is this, since the point is outside the grid, then you dont have a value of "d" (Area/ap).
How do you select this value, do you use one from the neighbours?
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
about reference pressure adam2008 CFX 1 May 17, 2011 09:03
Reference Pressure Set Up Explorer FLUENT 0 May 11, 2011 03:58
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 16:59
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
