flow rate decrement
Old   August 5, 2008, 11:12
Default flow rate decrement
d.h.
Hi!
I have one question for 3d channel flow simulation. That is the flow rate decrement. I checked the flow rate for each time step. As followed, that decrease continuously.
if nstep = 1, flow rate = 0.839421 if nstep = 5000, flow rate = 0.776719 if nstep = 10000, flow rate = 0.743256
For periodic b.c. I use constant pressure gredient((density*friction velocity^2)/(the half width of channel)) in u-momentum NSE.
I don't know that I look wrong part.........
Old   August 5, 2008, 13:05
Default Re: flow rate decrement
pankaj saha
hi, i am also working on the same , facing some problem. Would you like to discuss with me.
Please, tell me the following---- Domain size, grid, Re, time step, and initial condition. i hope you are running a incompressible code.
what is the exact value of presure gradient you are using. i mean the numerical value. If you are using non-dimensional code--and then the value of pressure gradient shoud be 1.0 and it will be added to the x-momentum equation .
Also, in initial condition , are you using random perderbation?
Old   August 5, 2008, 21:05
d.h.
hi, pankaj saha
my code's details are
domain size : 2(streamwise)*1(normal)*2(spanwise)
staggered grid, 16(streamwise)*64(normal)*32(spanwise)
Retau=395(for friction velocity and the channel half width)
i.c. : u=-1.5*y(y-2) (i don't know generating perturbation....)
i don't use non-dimentionalized NSE.
constant pressure gradient = friction vel.^2/half width
since NSE is devided by density, density is not.
friction velocity used is obtained by averaging all value near the wall(including north and south wall)
i think flow rate decrement may be induced by no slip b.c.
but i don't find my faults near the wall.
Old   August 6, 2008, 06:18
pankaj saha
hi,
you are telling that, you are calulating friction velocity by averaging at near wall. that means at every timestep it will vary and your pressure gradient and Retau will vary. i hope this is wrong. you are using dimensional code.then you are supplying seting viscosity not the retau in your code. i think your viscosity=utau*0.5/395. here you need Utau. normally, people take Utau=1 and set viscosity. from that your pressure gradient will have a constant value=2.0 in your case. just check the formulation of getting mean pressure gradient.
also, your x-dimension is very less compare to eddy size. take 2pi=6.3 minimum, othwerwise you will not get anything..also, grid should be large 50x66x60
try...
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 17:22
Mass Flow Rate student87 CFX 4 January 2, 2010 05:45
Can circum-avg-axial give flow rate? Amit FLUENT 0 January 10, 2007 12:20
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
