FLUENT + QUESTIONS
Old   July 29, 2008, 11:15
Default FLUENT + QUESTIONS
kospan
Hi. I want to learn some information for analysys of fluent.
1 question: If i have a 3d geometry (for examnple 3d pipe, how can i see the allocation of each quantity of analysys, such as velocity,pressure, on definite level of field? for example: if i have a straight 3d pipe and i do the anamysis at it and after i want to see results on the crosswise level of pipe(as axis tomography), how do i this?
if i dont find any way for this problem, i will not can see the results at inside of pipe because it is looked the colors of surfase of pipe.
Old   July 29, 2008, 13:17
Default Re: FLUENT + QUESTIONS
mettler
I am not sure I understand your question, but you can create planes anywhere within the geometry and investigate anything in that plane. So, if you want the crosswise results, just draw a plane across the pipe and view the results in that plane.
Old   July 29, 2008, 19:10
underGroundMan
I would suggest you do some tutorials. That should help.
Regards
Old   July 30, 2008, 03:43
pankos
ok. You understand ok. If it is not occured else, i will do thus. So, while i make the geometry, i will form athese surfase which on i want to see the allocation of analysis.
But if there was way which i can see with a camera of fluent all level where i want, it will be more easy.
Old   July 30, 2008, 17:30
underGroundMan
Sorry did you say something?
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Fluent general Questions andygir FLUENT 0 May 20, 2010 13:40
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 13:49
Simple fluent questions temp3733@gmail.com FLUENT 0 May 18, 2005 13:50
