Evaporation heat loss modelling (water temperature below saturation)?
Old   June 17, 2015, 19:37
Default Evaporation heat loss modelling (water temperature below saturation)?
Ahmed
ahmedmmx is on a distinguished road
I’m looking for evaporation heat loss correlation from water surface to almost stagnant air. The water temperature is less than saturation temperature ranging between 15 to 80 degree C. Most of the correlations I found are for quite high air velocities.
This appropriate correlation will be implemented in a UDF to simulate the heat loss from water surface.
Hope somebody can give suggestion **
ahmedmmx is offline   Reply With Quote
evaporation
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Below Saturation Temperature Evaporation amit.garg FLUENT 0 May 11, 2015 04:59
Transient convective heat transport - temperature diverges haakon OpenFOAM Programming & Development 2 November 8, 2013 04:35
Heat loss through walls franzdrs FLUENT 6 March 29, 2010 13:11
Heat loss through walls franzdrs Main CFD Forum 2 September 30, 2009 07:33
