CENTRAL STENCIL FOR WENO 4th ORDER SCHEMES
Old   July 20, 2008, 15:19
Default CENTRAL STENCIL FOR WENO 4th ORDER SCHEMES
Alberto
Hi to everybody. I'm writing a monodimensional code for solving shallow water equation with a WENO-based scheme. Do you know how to get the four coefficient of the third order polinomy ax^3+bx^2+cx+d for the central stencil? I mean: for the central stentil I think you use the cells i,i-1,i-2,i+1,i+2, so you have 5 equation and 4 unknown coefficient. Maybe is good to solve it with the least square method and the get the coefficients in this way?For the other stencil is straightforward because I have always 4 cells and so 4 coefficient and 4 equations. nobody have experience with that?is it correct this procedure? thanks a lot Alberto
4th order central scheme mmahdinia OpenFOAM Running, Solving & CFD 28 February 9, 2017 00:32
4th order schemes in channelOodles maka OpenFOAM Bugs 9 January 19, 2009 12:58
2nd order conservative schemes taw Main CFD Forum 1 September 16, 2008 08:05
CFL condition for higher order schemes Shyam Main CFD Forum 2 February 14, 2008 15:24
4th and 5th Order TVD Runge-Kutta Methods saygin Main CFD Forum 2 January 30, 2006 12:45
