Temperature (T) reactingFoam is diverging
Old   June 11, 2015, 06:07
Default Temperature (T) reactingFoam is diverging
Jesse Thomas
jessethomas5 is on a distinguished road
Hi All,
I am relatively new to OpenFOAM, and am trying to use reactingFoam with reactions turned off to simulate gas spread.
My setup is modelled off a real wind tunnel experiment where a constand wind is injected in the positive x direction at 10m/s, and gas enters the domain through a smoke-stack attached to a building at 100m/s.
When I set the simulation running with an adaptive deltaT, the time-step is adjusted to be increasingly small to the point the simulation will never seem to finish. When I set deltaT to be fixed, temperature seems to diverge and repeatedly get the following warning:
--> FOAM Warning :
From function janafThermo<EquationOfState>::limit(const scalar T) const
in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = 65.5492
Any help or suggestion anyone can provide would be immensely helpful!
Thanks!
jessethomas5 is offline   Reply With Quote
adaptive-time stepping, divergence temp, gas dispersion, reactingfoam
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 11:02
Question about temperature calculation in reactingFoam?? lfgmarc OpenFOAM Programming & Development 0 December 27, 2011 22:55
