June 10, 2015, 06:37 |
Swirl Flow simulation in a burner
Raman Chawla
Hello everyone
I am simulating a swirl (COLD) flow in a small size burner using pointwise and CFD++. The model I used is "preconditioned/Pressure based compressible RG NS/Euler" with realizable K-epsilon model. The flow parameters consist of 2 non-reacting fluids of different densities. The geometry is axisymmetric and I tried to model 2D model of it by two ways. 1. By using the geometric symmetry of the body, I simulated only half of it. 2. By Using the full 2D model of the geometry. For the first simulation (Using the symmetry of the body) I got the converged result But for the second simulation the residue is oscillating and the output is not giving any meaningful result. I am trying it for just with normal velocity vector (no swirl given till now). Pictures attached. Thanks in anticipation. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
how to get a time-accurate solution in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 4 | January 20, 2015 08:11 |
swirl inlet velocity for a 2-d axisymmetric flow | zahrarashidi | OpenFOAM Running, Solving & CFD | 2 | January 12, 2015 08:01 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 11:13 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 17:29 |
