problem with boundary layer
Old   July 11, 2008, 06:19
Default problem with boundary layer
Bharath
hello everyone,
I have a problem regarding the simulation. my geometry consists of a ramp along with the sidewall which is at one end of the ramp .sidewall being triangular and is just a plate. I am using a research code for simulation. the problem is I am getting a good boundary layer dveloped on the ramp but could not get on the sidewall. on the sidewall i am able to get BL only in the 1st cell. the grid size is fine enough y+ is 1 to capture the boundary layer and i am running viscous simulation. does anyone have an idea why BL is not developing on the sidewall.
Old   July 11, 2008, 10:06
Default Re: problem with boundary layer
Patrick
I have a little difficult to understand exactly the symmetry of your flow and the domain of the simulation. What is the direction of the flow...If this is a 3D, then you have more than just a wall and a "ramp", and what is meant by a ramp? Did you check that the viscous terms enter the equations in all the dimension? Not sure also where the "triangular" enters the picture. If you have a link to the exact problem or a image, or something. The BL will develop when the fluid flows parallel to a surface onto which the velocity is set to zero. Make sure you don't have on one of the surface a non-slip condition. If the viscosity of the flow is nu, then the bouundary layer will develop on a size D, where
D =nu/v
and v is the velocity of the flow (In the boundary layer one has a Reynolds number of order 1). So make sure you have the size D over at least a few cells/grid poins.
Rey = (D*v)/nu = 1 in the BL (this is a first approximation). If you increase the viscosity you will increase the size of the BL, so that's also a good way to check what's happening.
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 15:16
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 07:57
Setup of flat plate problem for laminar layer pankos Main CFD Forum 3 August 9, 2011 18:37
2D Boundary Layer Development in CFX11 Chris Basciano CFX 1 August 28, 2008 17:15
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
