June 10, 2015, 04:10 |
XFlow file import problem
Anonymus
I have been facing a problem in xflow. I made a file from Solidworks which is 1metre by 1 metre. I converted it into .stl format and imported it into xflow. The preset wind tunnel dimensions in xflow are [(12,4,6) metres]. When I imported the file into xflow the geometry turned out to be 1000 times bigger than the original dimension and hence it is out of the preset domain. I'm attaching 2 screenshots of the same.Could please help me with this problem
Scrnshot 1: The geometry in top plane after being imported into xflow which is (1000x1000) metre Scrnshot 2: A comparison of the domain size and the geometry size Attachment 40030 Attachment 40031 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
