Pressure Boundary Conditions
Old   July 10, 2008, 14:06
Default Pressure Boundary Conditions
kantipudi
Hi all,
I have a rectangular inlet and two rectangular outlets. I am using the pressure inlet and pressure outlets BCs.
I know the mass flows, in and out, at the boundaries. For these mass flows, initially I plotted the total pressure and Static Pressure Contours. As a next step, the mass flow boundary conditions are replaced by pressure boundary conditions and I used the plotted pressure values to get the initial mass flow rates(Total pressure as input at Pressure Inlet and respective Static Pressures as inputs at the two outflows). Can I expect to get the initial mass flow rates with which I started the problem?(Actually I am trying to verify my solution)
Because what happened is when I checked the velocity vectors, air is actually flowing 'into' one of the outlets. Also I didn't get the initial mass flow rates at the outlets. Inlet is working fine.
Could some one please help to make the flow 'out' from the outflow and with the mass flow rates at the outlets?
Thank you.
Old   August 10, 2008, 05:07
Default Re: Pressure Boundary Conditions
Anishtain4
let the outflow be solved by the pressure condition then take an integral of inflow and outflows. after that you can multiply the outflows by the fraction you expect. else you should let the pressure define it itself. former is the best way warrant continuity in the computational field.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Pressure Boundary Conditions Dave FLUENT 2 June 8, 2009 18:05
pressure boundary conditions A.Shaija Main CFD Forum 0 June 30, 2006 01:51
How to Define Pressure Boundary Conditions? Sheenu Main CFD Forum 4 May 12, 2000 13:52
