2d turbulent flow parallel plates matlab
Old   June 8, 2015, 20:07
Default 2d turbulent flow parallel plates matlab
P_P
P_P is on a distinguished road
I am currently trying to determine the turbulent velocity profile with matlab for a flow between two parallel plates. In order to do so, I am using the universal velocity profiles of Karman and Taylor/Prandtl. The veloityprofile is considered to be symmetric.
In both cases the velocity gradients close to the walls show realistic behaviour. Still I have my doubts concerning the values on the centerline where the velocity profile shows a peak. Does anyone know models which represent a smoother transition on the centerline or rather a better approximation for high y+ numbers?
A plot of the velocity profile and the corresponding Matlabcode can be found in the appendix.
Every input is welcome
Greetings
P_P
P_P is offline   Reply With Quote
Old   June 9, 2015, 04:57
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Greetings
P_P
I suggest plotting the velocity u+ versus y+ so that you can better check for viscous sub-layer and log region
FMDenaro is offline   Reply With Quote
Old   June 9, 2015, 07:57
P_P
Hello FMDenaro,
thanks a lot for your fast reply. I have plotted u+ versus y+. The linear behaviour of the laminar sublayer can be seen for y+<11.5.
You can see the the plot in the appendix.
Greetings P_P
Old   June 9, 2015, 08:00
Hello FMDenaro,
Greetings P_P
to check further, you can superimpose the law u+=y+ and the log law using a logarithmic scale
Old   June 9, 2015, 10:42
P_P
I don't know if I unterstood you well. I have created a semilogarithmic plot u+ versus y+. What is the idea behind checking the laminar sublayer for my problem?
Old   June 9, 2015, 12:30
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Looks reasonable.
The "peak" in your initial figure is due to the fact that the equations you used are for the flow over a flat plate with an infinite fluid domain. Not for a fluid between parallel plates.
flotus1 is offline   Reply With Quote
Old   June 9, 2015, 13:11
P_P
Hello flotus1,
thanks for your reply. Do you know any models which offer a better desciription of the velocity profile between two parallel plates? Or is it unevitable to excute a CFD simulation with common CFD software in order to export the velocity profile.
P_P
Old   June 9, 2015, 15:28
flotus1's Avatar
Alex
I havent come across any analytical formula for this case.
However there is plenty of DNS data available for turbulent flow between 2 parallel flat plates. Here is just one example...
log law, matlab, turbulent flow
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
Nusselt Number for flow between flat parallel plates vijud25 FLUENT 2 November 23, 2015 13:29
turbulent or laminar flow student2008 Main CFD Forum 5 August 24, 2013 06:33
Turbulent Flow in Straight Square Duct - k-ep Validation mcclud STAR-CCM+ 2 August 7, 2012 17:56
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
