I have two surfaces and a paste (gel) in between. How can I simulate the gel flow?
Old   June 3, 2015, 19:47
Default I have two surfaces and a paste (gel) in between. How can I simulate the gel flow?
Mohammad Ghazvini
mahmohammad is on a distinguished road
I have two surfaces and a paste (gel) in between. One surface is pushed towards the other surface.
Let's say there is a drop of a paste (gel) on a plate (bottom plate), pressure is exerted on top of the drop by moving the top plate towards the bottom plate. With this movement, the drop will start to squeeze out from the sides. How can I simulate this with ANSYS or solidworks?! Are there tutorials that can help me?
Thank you very much,
Moe
mahmohammad is offline   Reply With Quote
gel, paste, pressure, squeeze
Mass flow discrepancy BenMUC CFX 3 May 2, 2014 04:29
Is it possible to simulate fluid between to surfaces? pingpong Main CFD Forum 4 November 13, 2013 00:30
parallel code samiam1000 SU2 3 March 25, 2013 05:55
How to simulate and test various cutting edges and cutting surfaces? NickDaw Main CFD Forum 0 September 29, 2011 13:57
[GAMBIT] flow over extended surfaces in a channel (2D) abhishek_singh ANSYS Meshing & Geometry 0 November 9, 2010 19:09
