grid independence
Old   July 2, 2008, 09:40
Default grid independence
anne
I am checking grid independence in my case, which is a external air flow on the airplane. i am just wondering how much difference is acceptable among different mesh sizes. because no matter how fine the mesh is, the solution can't be exactly the same. there are always a tiny difference. it there any rule?
if any of your guys would like to have a look of my solution, i will send it to you.
many thanks
Old   July 2, 2008, 10:44
Default Re: grid independence
mettler
I believe there are a few ways to do grid checks. I did mine by comparing an average value of 'planes' that I had set up within my grid with different grids. For example, I would check the average temperature of the plane at different grid sizes. When I plotted the value vs number of cells I could see when the grid was too coarse. I would also check the value vs the changed grid count. For example, I would compare the value obtained at grid A with 1000 cells to that of grid b with 500 cells and have a criteria set that it would have to meet - ie..can only change by .001. Grid check used to be used to help with computational time as well as accuracy, but since computers have gotten so much more powerful it is really just an accuracy check now. that is my 2 cents worth anyway
Old   July 3, 2008, 05:57
anne
thanks a lot, mettler,
your idea is really helpful for me. I am just wondering another thing, the criteria, is it a absolute one or a relative one. I guess it should be a relative one. what's your definition?
thanks again
Old   July 3, 2008, 08:02
mettler
my criteria depended on what I was looking at. If I were looking at temperature my results would be something like this.
Cell Count Temperature Plane ---------- ----------------- 5000 300.514 4000 300.515 3000 300.514 2000 300.485
Then I would look between 3000 and 2000 if I was trying to optimize it.
Again, this was just done to help with computing power. From the numbers above 4000 would be just fine, since it didn't really change above that or below it. In the case of temperature anyway.
Old   July 3, 2008, 08:41
anne
ok, I see.
I also wonder if you have tried to compare the variables difference with your RMS residual. Do we have to keep the variables difference in the order of residual, say 1e-5 or 1e-6.
many thanks, really
anne
Old   July 3, 2008, 09:30
mettler
I think that will be up to you. I wouldn't waste too much time on this though. I would show that your answers do not change appreciably between different numbers of cells and then just go from there. If I remember correctly, I compared my variables to the order of my convergence criteria. You just need to find the cell count in which your results start to change and then increase that number of cells. The number of cells is going to be dependent on what you are looking at too. If it is a complicated geometry, then you are going to need a lot of cells to capture everything that is going on.
Old   July 3, 2008, 12:06
anne
thanks a lot, mettler.
I will follow your guide and see what will happen.
all the best
anne
Old   July 3, 2008, 12:13
mettler
a plot is the best way to see it, and to show it (ie to a professor or something like that). pick a variable and record its value with different cell/grid counts and plot. You will get a horizontal line until the grid gets too coarse and then it will fall or go up - meaning the results are bad. You want your cell count to be on that straight line. My X-axis was my cell number and the Y-axis is the variable result. It gives you a nice graph to show how you arrived at the cell count that you did
Old   July 3, 2008, 17:59
littlelz
mettler,
thanks again.
that's exactly what I am doing, like you said, the straight line will go up or go down, and it's a very nice show.
best regards,
anne
Old   August 6, 2008, 10:38
Default how to model a entrifugal pump using gambit
Mel
hello..
i am working on modelling a centrifugal pump (the impeller and its spiral casing).can anyone help me how to do this?i really need steps or procedures to draw the pump impeller in gambit.
thanks.
Old   August 6, 2008, 10:56
Default Re: how to model a entrifugal pump using gambit
  #11
mettler
don't draw it in Gambit..draw it in SolidWorks or ProE and import it.
Old   June 24, 2010, 03:44
say tang
Ser tang is on a distinguished road
Originally Posted by anne
;55700
many thanks
Dear Sir ,
Can you send your example to me as I have no ideas how to do grid independency test ? Thanks you very much . Your cooperation is highly appreciate.
Ser tang is offline   Reply With Quote
Old   June 24, 2010, 03:48
say tang
DeaR Anne ,
For your information , I would like to view , how you do your grid independency test. My e-mail is ser.tang@yahoo.com , hope to receive the feed back from you soon. Thanks you very much .
Old   June 24, 2010, 04:17
say tang
Originally Posted by mettler
;55707
Hi mettler,
I would like to know how to do grid independency test? your ooperation is appreciated . Hope to hear from you soon. Thanks you very much.
Old   June 24, 2010, 10:02
say tang
Originally Posted by Ser tang View Post
DeaR Anne ,
Dear Sir,
can you guide me how to do independency test ? thanks alot
Old   June 24, 2010, 10:07
Exclamation reply:
  #16
Tanmoy
tanmoy95 is on a distinguished road
hi !..to make a grid independancy test make the mesh finer ..increasing the no of meshes 2^n times the previous, and analyse everything..if u see the data does not change much,( a predefined value say 0.05) then u say the results have decayed to convergence in response to grid independancy test!..thank u
tanmoy95 is offline   Reply With Quote
Old   June 24, 2010, 10:08
say tang
;55707
Dear Sir,
Can you guide me how to do the grid independency test as I don't know how to do it. Is it , I need to obtain the " grids " , meaning using the number of small grids devide with the bigger number of grids and the multiply by 100% , so I can obtain the results the independency test results . Is this consider as the independency test? Your cooperation is highly appreciate . :* :P :O :/
Old   June 24, 2010, 10:14
say tang
Dear Sir,
I still not sure which icon i need to click ,so I can do the independency test.....meaning of this statement?? " a predefined value say 0.05) then u say the results have decayed to convergence in response to grid independancy test" .I hope you can guide me deeply as , my foundation is quite weak. Your cooperation is highly appreciate . Thanks you very much. :* :P :/
Old   June 24, 2010, 10:21
say tang
Dear Sir ,
Where can I see predefine value state in fluent software ??
Old   June 24, 2010, 10:50
Default reply:
  #20
Tanmoy
i just talked about the theory ..crudely speaking ,to make a grid indpendance test what u need to do is increase the mesh quantity manyfold, and see if u find any considerable change in the data..if not then ur solution has reached grid independance !..
i dont know if there is a switch to make the test..u can try it out by remeshing ur model every time in gambit !...:-)
grid independence questions lucifer FLUENT 0 December 14, 2009 20:59
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 17:50
Grid independence check Mattis Voss FLUENT 1 November 23, 2005 11:30
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 09:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
