Level set method for detonation
Old   June 30, 2008, 03:07
Default Level set method for detonation
Amir
Hi I want to use level set method for 2-D detonation problem. Is it possible? what about Ghost fluid method?
Old   July 2, 2008, 16:25
Default Re: Level set method for detonation
jinwon park
I am solving underwater explosions using a GFM. Due to discontinuous adoptation of equations of state between water and explosive gas, I have suffered from stability problems in treating discontinuities across the material interface. The LSM was coupled in the GFM to provide the interface information. However, the sole use of LSM may not be applicable in detonation simulations because the Eulerian approach incluidng the LSM provides mixed elements in which fraction of fluids are presented. To remove the diffusion near the interface, a sharp interface method such as the GFM, the immersed interface method(IIM) has been often recommended. Please see the reference about the LSM, the GFM presented by R.Fedkiw who is an invertor of the LSM and GFM.
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
Set liquid level in a Tank chemeng OpenFOAM 4 April 7, 2010 00:46
level set method for simulating detonation Amir Main CFD Forum 4 July 31, 2008 16:13
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
level set method with TVD scheme? zhanglei Main CFD Forum 1 April 25, 2000 15:01
